Thanks for the update Taner, i wondered already why nobody paid attention to that question
Just a little update: i was able to spend some noticeable amount of time on the aaf decoding part and sure it turns out that i have to understand most of the specification but there was some good progress.
At the current state, i am sure that we will need to render all audio effects before the export as well. The best thing i can currently do is to translate the project into a cutlist for ffmpeg. We will see if ffmpeg is able to do this frame accirate or not and after that in some months we could maybe go on and support some transitions and simple audio filters bit i am not sure we ever get there.
@all, please upload more example aaf exports, especially exported with the settings ghatis showed above. But in a later stage of this project, i will need to be able to compare my output with the avid output. So it would be good if you send me aaf sequences that are available for you for multiple weeks/months as well.
In particular i am interested in very complex stuff as well but anything will help!
