True audio passthrough with "A/V Media" filter ?
ainz
Re: True audio passthrough with "A/V Media" filter ?
Post by ainz »
so what im trying to work with is anime!.
So most of the source audio would be AAC, or AC3, which i want to merge with the encoded video.
the Source video will have to go through a debanding filter with avisynth, which is whats causing the issue, I am able to extract the audio, and encode the video and save them in a tmp folder.
Im not sure how to use the command executer, to merge both these files.
Ok, so if you have video in one file and audio in the other, all you need to do is a commandline executor node with about this content:
cmd /C ""%s_ffmpeg%" -i "__PATH_TO_VIDEO__" -i "__PATH_TO_AUDIO__" -map 0:v -map 1:a -codec copy "__PATH_TO_OUTPUT__""
Where
  • __PATH_TO_VIDEO__ would be like %s_source% in case you used one of the inbuilt encoders.
  • __PATH_TO_AUDIO__ would be the full path to your previously extracted audio, you need to store/set the filename in a variable using the populate variables node for example.
  • __PATH_TO_OUTPUT__ could probably be like "E:\videos\%s_original_name%.mov" for example.
And for explaination, as we have 2 times -i in our ffmpeg command, the maps work like this:
-map 0:v copies all video streams from the "first input file" to the output file
-map 1:a copies all audio streams from the "second input file" to the output file
-codec copy of course takes care that we rewrap only instead of encode audio and video.
As for the "temp dir", you can use %s_job_work% - this a "unique per job" subdirectory in the ffastrans cache folder, it will be housekeeped by ffastrans (if you didnt set your workflow to "keep work dir always"). If you do this, you could e.g. extract your audio before/while filtering/ encoding the video using this commandline:
cmd /C ""%s_ffmpeg%" -i "%s_source%" -map 0:a -codec copy "%s_job_work%\original_audio.mov""
Which leads to __PATH_TO_AUDIO__ to be fixed: "%s_job_work%\original_audio.mov" - as the work directory is unique per job, you don't need to take care of a unique filename or such.
Re-thinking this, there is no real need to first extract your audios, so actually __PATH_TO_AUDIO__ can just be %s_original_full% and no extra step for audio extraction needed.
ainz
Post by ainz »
@emcodem Thank you for taking the time to explain this out for me. im still getting errors, but i'll keep trying to fix, i must be doing something wrong.
In the mean time let me drop the link to the workflow, maybe that would give you an idea of what i seem to be doing wrong.
https://www.transfernow.net/dl/20210329moYBZwWS
thank you again for all the help and advice
Hey,
thanks, a workflow is always good to have so i know what you are looking at.
So, first you should get the webinterface when doing these kind of experiments. It lets you easily investigate the logs and therefore see whats happening. E.g. for your commandline processor, you can copy the actually executed command from the log viewer and try it manually on commandline.
Second, your custom avs just returns the original m_clip, so your neo_f3kdb is not even used at all. Instead you should do like this:
LoadPlugin ("%s_ffastrans_dir%\Processors\avs_plugins\neo-f3kdb\x64\neo-f3kdb.dll")
m_clip = neo_f3kdb (m_clip, range=16, y=64, cb=64, cr=64, grainy=0, grainc=0)
Return m_clip
Third, the final wrapping commandline seems to basically work. I just got some errors regarding timestamps but finally got it to work when using mov instead of mkv as output. I believe there are some setpts commands or such available in ffmpeg to indicate that it should start from 0 with all timecodes but i don't have it at hand right now.
try using
-use_wallclock_as_timestamps 1
before the -i for the video
ainz
Post by ainz »
@emcodem
thank you again for helping me.
so i am able to run the command structure now, But it seems to create 2 files.
1, audio only
2. video only
this is the command im using.
%comspec% /C ""%s_ffmpeg%" -use_wallclock_as_timestamps 1 -i "%s_source%" -i "%s_original_full%" -map 0:v -map 1:a -codec copy "D:\FFtrans_work_folders\Encoded\%s_original_name%.mkv""
Hmmm so the command basically cannot create 2 different files as it is. I guess it's more a matter about how you start your jobs.
Is your input file "one file" with audio and video or do you need to start with 2 different files, one for audio and one for video?
A screenshot of your job monitor would be good to see :-)
ainz
Post by ainz »
the input file is 1 file containing both Audio and video,
it just refuses to map the subs and audio.
i'll keep experimenting, im almost there i think.
cool 8-)
if u need help, please send some job log or some further data. The more data you provide, the easier you make it for us to help you. Workflow+Short File would be optimal (upload to ffastrans.com/share)
mrazik
Post by mrazik »
Hi gents,
can you please share the workflow again? Looks like the link is unaccessible.
Many thanks,
mrazik
FFAStrans 1.2.2
Webinterface 1.2.0.4
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
