Help with network output
Re: Help with network output
Side note; I'm now getting a small popup saying "24" (see attached), which happens when processing the x264 portion of my workflow. I wasn't seeing this before, so perhaps it's caused by the new processors file? I have to hit "OK" for it to proceed, then it finishes the process successfully. Any ideas what's causing that?
- ffastrans_error.png (1.06 KiB) Viewed 4815 times
Oh dear! Eh, well, you're actually running a version of the processor that was ment to be an update for the 0.9.4 branch but never released. So it might have some peculiarities.
Try this new attached.
- processors.xml
- (798.7 KiB) Downloaded 496 times
And that appears to have fixed it! I'm blown away by your support, thank you again.
