Custom ffmpeg - XDCAMHD 1080i50
Re: Custom ffmpeg - XDCAMHD 1080i50
sainrishab wrote: Fri Dec 31, 2021 1:56 pm Great! thanks for sharing.
By the way, there was actually a way to use the internal encoder without going through the hassle of creating a custom FFMpeg script and that was by using Avisynth.
It would have been as easy as:
Watch -> AV/Decoder -> Custom Avisynth Script -> Encoder XDCAM-50 -> Delivery
For progressive sources, while for interlaced ones it would have been:
Watch -> AV/Decoder -> Deinterlacer -> Custom Avisynth Script -> Encoder XDCAM-50 -> Delivery
This is because if you hardsub subs on an interlaced video without bobbing it first and re-interlacing it after, you will end up with interlaced video and progressive subs which is not the best thing ever.
That being said, the custom Avisynth Script would have been as easy as:
# Variables: m_clip = The last returned AviSynth media
# _ffas_video = <original video>
# _ffas_audio = <original audio>
# _ffas_height = <source height>
# _ffas_width = <source width>
# _ffas_work_fdr = Working folder for the workflow
LoadPlugin("\\yourffastransdir\processors\avs_plugins\VSFilter.dll")
m_clip=TextSub(m_clip, "subs.srt")
Return m_clip
Of course you would also have to download the latest version of VSFilter from here: https://github.com/pinterf/xy-VSFilter/releases and put it in your installation folder inside processors, avs_plugins.
Cheers,
Frank
