Autoit - Erro allocating memory
authorleon
Re: Autoit - Erro allocating memory
Hello, also I have bypassed the "inserts" and I get this.
Oh, I'm sorry! The processors.a3x you got is a part of a slightly newer version I'm working on which incorporates the mtmodes.avsi by default. Should be easy to fix. Just put the attached file in the "FFAStrans\Processors\AVS_plugins" folder and try again. No restarting/stopping etc. needed.
- mtmodes.avsi
- (16.62 KiB) Downloaded 675 times
authorleon
Hi, ok a step closer. I am not sure what I am getting this error now.admin wrote: Sun May 10, 2020 8:54 am Oh, I'm sorry! The processors.a3x you got is a part of a slightly newer version I'm working on which incorporates the mtmodes.avsi by default. Should be easy to fix. Just put the attached file in the "FFAStrans\Processors\AVS_plugins" folder and try again. No restarting/stopping etc. needed.
"... fourcc V210". I have also supplied the media informaiton.
I have also tired the uncompressed AVI as well. I am sure I am missing something here.
Thank you
authorleon
Okay, I have it working but with VERY strict settings. However, it is using a VERY old CODEC.
It would be great to have uncompressed AVI.
Please let me know.
Thank you
Please let me know.
Thank you
authorleon
Thank you again for the support. I have been testing out and it all seems to be stable.
If anyone know of a better CODEC instead of MS V1, I would appriciate it. It has to be at 1080.
Thank you
Thank you
Hi, try selecting UYVY instead of V210 which is not supported in AviSynth. This should work. Just tried it with 1080.
authorleon
Fantastic... Works perfectly!!!!admin wrote: Mon May 11, 2020 7:11 am Hi, try selecting UYVY instead of V210 which is not supported in AviSynth. This should work. Just tried it with 1080.
I am not sure how to make this post as solved.
Thank you again and GREAT work!!!!
Happy it worked out for you
authorleon
Hello, I just wanted to know when the next update is going to be released with all the small your modifications please. And I imagine they would include all of these modifications. Thank you very much
authorleon
Hello, chasing up this.authorleon wrote: Sat May 16, 2020 3:39 pmHello, I just wanted to know when the next update is going to be released with all the small your modifications please. And I imagine they would include all of these modifications. Thank you very much
