XDCAM processor with opAtom and cyrillic filenames
Re: XDCAM processor with opAtom and cyrillic filenames
Hi 3dsasha,
Could you please download and test the brand new FFAStrans 1.2.1 release? It should fix your problem Please try and report back! Thanks :-)
https://github.com/steipal/FFAStrans-Pu ... ns1.2.1.7z
3dsasha
Post by 3dsasha »
Thanks, this version is working fine!!
XDCAM file contents present.
A little but not so important bug yet happens. I use some number of keyboard layouts besides EN - RU, BY and others. When I change workflow, I try to save it by Ctrl-S. But if current layout is not EN, workflow cannot be saved anymore. Switching to EN don't help. After this mistake I need to re-run ffasttrans to edit and save workflow.
Thanks for the feedback and glad the new version fix your issue! :-)
Not sure what's going on with the "Ctrl+S" issue :?:
When I try and switch between different layouts (EN, NO, RU, BY) I don't have the issue. FFAStrans monitors the "Ctrl+S" combination when active and that's all there is to it. Not much magic goin on here. Does saving using mouse work (right click in editor -> "Save workflow") ?
3dsasha
Post by 3dsasha »
Right-click is SOLUTION!
Something wrong happens when I edit a text content of processor fields, RU or EN layout used. After that Ctrl-S becomes not responsible.
Is it only FFAStrans behaving this way or are there others too? CTRL+S i pretty much the standard for "all" programs for saving.
3dsasha
Post by 3dsasha »
Hello! Suddenly I found that Ctrl-S is not working not all times at non EN keyboard layouts. And other keys like Ctrl-V too, but now knowing this - no problem!
