Alpha Video to Luma Key
Re: Alpha Video to Luma Key
While we wait for Frank, maybe meanwhile just try ffmpeg in a cmd executor:
"%s_ffmpeg%" -i "%s_source%" -vf format=yuva444p16le,alphaextract,format=yuv420p "%s_source%_alpha.mov"
Note that we seem to have to trick ffmpeg to assume another pixel format in order to be able to retrieve alpha only.
video_m wrote: Mon Jan 10, 2022 5:39 pm Hello Frank,
the key stays black.
Thanks for the insight, now I know exactly what you mean: you wanna color the image with green using the transparency layer.
I came up with the right script for you:
#Indexing
FFMpegSource2("Wvd3_clean.mov", atrack=-1)
#Getting rid of evil frame properties
propClearAll()
#Keeping the alpha channel
ConverttoRGB32()
#Collecting data
my_width=Width()
my_height=Height()
my_framerate=FrameRate()
my_frames=FrameCount()
#Substituting the alpha channel with a custom image
mk=ExtractA().ConverttoRGB32()
bg=ImageSource("\\mibctvan000.avid.mi.bc.sky.it\Ingest\MEDIA\temp\green_screen_sample.png", fps=my_framerate, start=0, end=my_frames, pixel_type="RGB32").Spline64Resize(my_width, my_height)
top=last.Mask(mk)
Layer(bg, top)
#Going to 4:2:2 planar
Converttoyv16()
in FFAStrans, this would be:
ConverttoRGB32(m_clip)
propClearAll()
#Collecting data
my_width=Width()
my_height=Height()
top=last.Mask(mk)
Layer(bg, top)
m_clip=Converttoyv16()
return m_clip
and this will achieve the right result, so from this:
to this:
and as I always say: anything is possible with Avisynth eheheheheeh
if you want to keep audio, you need:
propClearAll()
#Collecting data
my_width=Width()
my_height=Height()
my_audio_channels=AudioChannels()
my_audio=GetChannels(my_audio_channels)
top=last.Mask(mk)
video=Layer(bg, top)
audio=my_audio
AudioDub(video, audio)
return m_clip
if you're using an Avisynth version prior to 3.7.1, you can toss "propClearAll()", so:
#Collecting data
my_width=Width()
my_height=Height()
top=last.Mask(mk)
audio=my_audio
return m_clip
As a side note, since emcodem says that I have no love for ffmpeg and algie said that we should provide an alternative way to Avisynth to do it for educational purposes, he (algie) created the command line to do the same thing in FFMpeg:
ffmpeg.exe -i "source_with_alpha.mov"  -i "fill.mxf" -filter_complex "[0]alphaextract[a];[1][a]alphamerge[mask];[mask][0]overlay[v]" -map [v]  -y "out.mp4"
Cheers,
Frank (FranceBB) and Livio (algie)
video_m
Post by video_m »
Thank you!!
but if i use the script than get i the error: "there is no function named 'ImageSource"
When i add: LoadPlugin("%s_ffastrans_dir%\processors\ffmpeg\x64\plugins+\ImageSeq.dll") to the script then is the key black and not green.
video_m wrote: Sat Jan 15, 2022 6:17 pm Thank you!!
Yeah loadplugin was implied.
About the key, make sure that AV Decoder is set to no decode, same as source for both video and audio
video_m
Post by video_m »
i make the mistake with AV Decoder NICE THIS WORK!!!! THANK you
