[Web GUI] Metrics doesn't show up. Hosts are up and running
Re: [Web GUI] Metrics doesn't show up. Hosts are up and running
So, did my recommendation with allow_embedded solve your problem now? I need to know!
Regarding which host had highest cpu at a given time, you can switch to a single host here:
Regarding the other grafana view i see 2 options, either you or me play around and try to create a corresponding dashboard. It will take some time until i do the next work on metrics, i am working on a preview player at workflow submission tab.
If you want to log in to grafana as admin, rename custom.ini to custom.ini.old, restart the service and login with admin/admin. Also you can open grafana directly on localhost:3004.
I should probably add an option to enable grafana admin login, i guess most guys that use metrics want to give it a try :D
Sidenote: all of the metrics stuff is designed in a way that you could easily collect the metrics from your own prometheus/grafana combo or any other prometheus compatible metrics collection system (zabbix etc..)
veks
Post by veks »
sorry for late reply.
Yes, it works now after changing the allow_embedding to true.
