setting max parallel running jobs
Re: setting max parallel running jobs
Hm i think all you want to do is open the workflow editor, jlick settings config and set the "max jobs per priority class to 5
Max queued jobs you normally dont care about but max running everyone cares about.
buddhabas
Post by buddhabas »
emcodem wrote: Wed Dec 18, 2024 10:52 pm Hm i think all you want to do is open the workflow editor, jlick settings config and set the "max jobs per priority class to 5
It does work!
Thank so much! :P
