Recursive Delivery for Folder creation
Re: Recursive Delivery for Folder creation
You have a "Media Distributor" processor node doing nothing in your workflow. Combined with "Max active jobs" actually reveals a shortcoming in FFAStrans I was not aware of and I will look into that.
Anyway, you probably got the "zombie"-node hidden to the left in the editor. Please press Ctrl+R in the workflow editor to reveal it then delete it by clicking on it while holding Ctrl. Then you must save the workflow to activate the changes. Also, set "Max active jobs" to 1 again and run the workflow to see if the behaviour has changed.
-stepal
jeroen.hennekes
Post by jeroen.hennekes »
Correct and resolved!
I read somewere to use Ctrl to delete a processor node, but then understood Ctrl+Delete...
So I didn't understand and finally dragged it out of the workflow editor (NOT.. ).
Now I get it, but I actually cannot relocate the Help instruction (shouldn't it occur under "Processor nodes"?).
I'm sorry about the delayed answer but help-screens not appearing correctly has been resolved in the latest release.
