Web Monitor
VladimirI
Re: Web Monitor
Post by VladimirI »
Dear Steinar,
looks like Microsoft Edge was a problem, in Firefox works fine.
Thank you
Re: Web Monitor
Ok? MS Edge seems to work as expected on my setup.
VladimirI
Re: Web Monitor
Post by VladimirI »
Actually monitor page works fine in Edge, only first (home page) isn't loading.
Re: Web Monitor
Hm, I have no problems with Edge and the "home page". Don't know that that might be and I probably wont use much time investigating it, unless I'm bored one day ;-)
gerst
Re: Web Monitor
Post by gerst »
I cant get it to work, I`m using windows server 2008. What could be the problem be? I`m using 0.9.1 version. thx
Re: Web Monitor
Hi gerst, thank you for using FFAStrans and welcome to the forum! :-)
Is the web-monitor not working at all? Does the discovery page work? Have you enabled the web REST service as application or are you running as service?
gerst
Re: Web Monitor
Post by gerst »
Hi!
Thanks for the reply, I have tried both as service and as app too..
Is there a doc with a step by step information how to use the web part of this great software?
admin wrote: Sun Oct 07, 2018 8:14 pm Hi gerst, thank you for using FFAStrans and welcome to the forum! :-)
Re: Web Monitor
The questionmark button "?" in the "Host" pane will explain how to get the web-service going. When you have it up and running, the URL in the same pane will open the api-discovery documentation where you also have the link to the web-monitor.
