Merge into one file
Re: Merge into one file
@Morty_
Qué exactamente, P2 o en general?
Morty_
Post by Morty_ »
Sorry. P2 panasonic
@Morty_
there is a "Combine all clips into one" checkbox in the P2 monitor, does it not what you want?
Morty_
Post by Morty_ »
yes, it works for me. Thank you
rlima
Post by rlima »
Hi guys,
I tried to use the P2 monitor to combine files into one single clip, but I guess it only works with a P2 folder structure, right? I was looking for a solution to merge clips in general, ideally from different sources and formats. Am I asking too much? :roll:
Congrats on the great software, btw!
Hey @rlima,
yes, P2 monitor is dedicated to P2 structures, you might misuse it by faking a P2 strucutre on the input but thats maybe not what you want :D
Please follow the concat thread from @taner: viewtopic.php?f=5&p=7897#p7897
I'll post some example later.
rlima
Post by rlima »
Hi @emcodem,
Thanks for the reply! I'll take a look into that concat thread.
