Custom FFmpeg fails with No video or audio found in media
Re: Custom FFmpeg fails with No video or audio found in media
I apologize, but there is no time and opportunity to restructure the working scheme, but honestly speaking I do not think it will help. The solutions described above, but these are quite basic problems that are not described anywhere. Found by experience. Thank you for your assistance.
I'm not sure I quite understood you last reply. Did your workflow work after placing FFAStrans in the root folder and installing Microsoft Visual C++ 2015?
I'm facing the same problem. I have already installed Visual C ++, and the program folder is in root.
However I still have the same result: No video or audio found in media.
When I use a custom ffmpeg without A/V Media, it works!
I am converting from MXF (XDCAM HD422) to WMV, using A/V Media.
Thanks.
Thanks.
[General]
watcher="WMV CH1 CH2"
folder=""
watcher_id=20171220174137
description=WMV CH1 CH2
Sleep=5
Default folder=1
Priority=2 (normal)
Last_mod_by=encoderdsp@DSPENCODER-01
Abberation=4
[Variable]
wf_size=120.75
start_proc=mon_folder 20171220-174201-263-e0e779c3c827
[Maintainance]
Delete_cachefile=1
keep_all_workdir=4
keep_failed_workdir=4
Cleanup=04:00
.flist_age=5
Run=2345671
[Special]
File_debug=1
Debug_file=C:\FFAStrans 0.8.2\Processors\.cache\wfs\20171220174137\logs
force_32bit=4
read_timecode=4
Abberation=4
Protected=4
Password=
[mon_folder 20171220-174201-263-e0e779c3c827]
execute_on=3800889
custom_node_name=WMV HD
folder=C:\Users\encoderdsp\Desktop\TESTE_IN
accept_types=
deny_types=
deny_paths=
attrib_read=4
attrib_arch=4
attrib_sys=4
attrib_hidden=4
recurse=4
localize=4
create_folder=4
growing_files=4
dirsize=0
filelimit=None
proc_x=-74.875
proc_y=251.5625
outbound=dec_avmedia 20171220-180240-234-92857fa962b9
[avs_v_deinterlace 20171220-174642-498-0a5a06301e15]
execute_on=3800889
deinterlac_type=Kernel
proc_x=649.625
proc_y=150.9375
outbound=enc_av_wm 20171220-174843-374-69731a6b1d11
enabled=68
[enc_av_wm 20171220-174843-374-69731a6b1d11]
execute_on=3800889
v_codec=Windows Media Video 7
a_codec=Windows Media Audio 7
v_bittype=CBS
a_bittype=CBS
v_bitrate=896
a_bitrate=128
format=WMV
only_audio=4
samplerate=44100
proc_x=830.75
proc_y=251.5625
outbound=dest_folder 20171220-175446-483-d18a36f7455f
enabled=68
[dest_folder 20171220-175446-483-d18a36f7455f]
execute_on=3800889
folder=Y:\ENCODER_OUT
suffix=
prefix=%s_wf_name%
overwrite=4
unique=1
case=None
drop_name=4
drop_ext=4
proc_x=1011.875
proc_y=251.5625
outbound=
[DSPENCODER-01]
Work folder=c:\.ffastrans_work_root\20171220174137
[farming]
list=
include=1
[avs_v_resize 20171220-180005-390-9fc3f157196d]
execute_on=3800889
quality=Lanczos
preset=Custom
interlacing=Autodetect
width=640
height=360
proc_x=468.5
proc_y=150.9375
outbound=avs_v_deinterlace 20171220-174642-498-0a5a06301e15
[dec_avmedia 20171220-180240-234-92857fa962b9]
execute_on=3800889
video=1
audio=1
a_decode=4
v_decode=4
a_method=Intelligent
v_method=Intelligent
x64avisynth=4
force8bit=4
proc_x=106.25
proc_y=150.9375
outbound=avs_a_acmapper 20171220-180304-890-ba8ed14330f7
[avs_a_acmapper 20171220-180304-890-ba8ed14330f7]
execute_on=3800889
audio_mapping=1|2|3|4|5|6|7|8|9|10|11|12|13|14|15|16|17|18|19|20|21|22|23|24|25|26|27|28|29|30|31|32
audio_muxing=2 (stereo)
proc_x=287.375
proc_y=150.9375
outbound=avs_v_resize 20171220-180005-390-9fc3f157196d
enabled=68
<?xml version="1.0" encoding="UTF-8"?>
<workflow>
<file>20171220174137.ini</file>
<data>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</data>
</workflow>
<template>
<file>avs_v_resize\437573746F6D.ini</file>
<data></data>
</template>
<user_variables>
</user_variables>
Hi rodnvs! I'm sorry but your post has slipped under my radar, but thank you for using FFAStrans and welcome to the forum!
There are some issues with the CBS bitrate encoding which has been addressed in the next release (0.9.0). So stay tuned. Hopefully it will be better.
PS: There is no longer any need to install any Visual C dependencies.
