Partially broken mp4 clip fails to encode.
Re: Partially broken mp4 clip fails to encode.
The encode took 20 minutes (approx 50fps) it counted up to 2510.72 but resulted in a 188k mxf which mediainfo says is 40ms in duration.
Ok, well then you need to send me the workflow so I can investigate.
It was attached in a previous post. Is there more you need?
Sorry, I forgot you had already posted the workflow. But ok, I must have been drunk when testing last time cause now I can't get it to decode properly in "Intelligent" mode but "Full decode" seem to "work". The "Intelligent" mode is created to kick of full decoding "when needed" but clearly, FFAStrans does not understand that it need to do that with this particular file. So, I will have to take a closer look at it and try and figure out what's going on. In the mean time you will just have to treat it as a special case and do some manual remuxing.
awesome thanks. Using full decode resolved the issue. I've made a special work flow for these sort of difficult files. Looks like we need a media analyser
running it through ffprobe -show_frames results in this output. There appears to be nothing out of the ordinary in the frames output.
Input #0, h264, from '1_04_R_08092016090000PM-352x288x25p.mp4':
Duration: N/A, bitrate: N/A
Stream #0:0: Video: h264 (Constrained Baseline), yuv420p, 352x288, 25 fps, 25 tbr, 1200k tbn, 50 tbc
[h264 @ 0x3449c80] Invalid NAL unit 8, skipping.
[h264 @ 0x3449c80] corrupted macroblock 7 16 (total_coeff=-1)
[h264 @ 0x3449c80] error while decoding MB 7 16
[h264 @ 0x3449c80] concealing 86 DC, 86 AC, 86 MV errors in P frame
