speed issue with new 0.9.4 FFAStrans version
Re: speed issue with new 0.9.4 FFAStrans version
Ghtais, can you please send me your workflow?
Ghtais
Post by Ghtais »
Hi steinar
this is my workflow.
bye
ghtais workflow.xml
(18.26 KiB) Downloaded 702 times
Ok, so the problem with AviSynth is that it does not have any metadata that says anything about color characteristics. So when encoding one need to take a guess. That guess can be wrong and this is probably what happens in your case. You can use the "Color conversion" filter to try and alter the colors. What are the properties of your typical QTref input source?
Ghtais
Post by Ghtais »
Ok thank you steinar to take time for this problem.
My footage is coming from AVID, YUV 4:2:2 REC 709.
I'am going to try the color conversion.
Bye
