Perfect, that was it must have renamed the folder at some point. For anyone else with the problem restart the services to apply the changes. The new webui looks amazing, it's great to drill down and see where the errors happened visually. Thanks for the great work.
Hi team,
I’m new in FFAStrans, so sorry if it’s silly question...
Is it possible to see in Webinterface list of Queued jobs like there’s a list of Running and Processed jobs in main view?
Many thanks!!!
Many thanks!!!
FFAStrans 1.2.2
Webinterface 1.2.0.4
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
@mrazik
welcome to the forum and thanks for using ffastrans!
That feature was there in 9.4 but it needed redesign after ffastrans 1.0 version and i was not yet able to invest the needed time. But be sure i'll update you here when i tamed that beast.
@emcodem,
you are awesome!!!
you are awesome!!!
FFAStrans 1.2.2
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
@emcodem Thank you for your tool.
But i have only 1 small problem. The Webinterface worked before on my other Server without any issues but now it is not showing Files just folders.
Is this a Problem anyone had before? and if yes how can i solve it?
Tim
Tim
Hey Tim,
That sounds like a permission issue, did you check the "credentials" of the windows service?
Does it work when you dont use it as service but execute server.exe manually?
Hello emcodem,
thanks to your fast reply.
I run the Services under the Power of Administrator.
If i try to run the Server.exe it closes itself.
hm, i guess the server.exe closes because another instance is already running.
It would be good if you can get it working by starting server.exe manually because it might show you some log information about possible reasons why we only see folders but no files...
To see why server.exe is closing, you need to open a cmd prompt first and then drag server.exe into the cmd window and hit enter, then you should see an error msg which you can post here. But most likely it is just because you forgot to stop the windows service...
Thats the errors i get
[ERROR] Trace: Global unexpected error: RangeError [ERR_OUT_OF_RANGE]: The value of "start" is out of range. It must be <= "end" (here: 49629647). Received 49629648
at process.<anonymous> (C:\Users\Administrator\Desktop\FFAStrans1.0.0\Webinterface\server.js:38:11)
at process.emit (events.js:196:13)
at process._fatalException (internal/process/execution.js:146:25)
[[14:23:20.909]] [ERROR] RangeError [ERR_OUT_OF_RANGE]: The value of "start" is out of range. It must be <= "end" (here: 49629647). Received 49629648
at new ReadStream (internal/fs/streams.js:93:13)
at Object.createReadStream (fs.js:1794:10)
at Object.createReadStream (C:\Users\Administrator\Desktop\FFAStrans1.0.0\Webinterface\server.exe:192:38)
at SendStream.stream (C:\Users\Administrator\Desktop\FFAStrans1.0.0\Webinterface\node_modules\send\index.js:796:19)
at SendStream.send (C:\Users\Administrator\Desktop\FFAStrans1.0.0\Webinterface\node_modules\send\index.js:707:8)
at onstat (C:\Users\Administrator\Desktop\FFAStrans1.0.0\Webinterface\node_modules\send\index.js:729:10)
at C:\Users\Administrator\Desktop\FFAStrans1.0.0\Webinterface\server.exe:223:21
at processTicksAndRejections (internal/process/task_queues.js:81:9)
[[14:23:20.919]] [LOG] Calling http://localhost:65445/api/json/v2/workflows
[[14:23:20.925]] [LOG] Filebrowser request to: c:\Users\Administrator\Desktop
Oh wow, i don't think another user had this.
To get this error message, what you do is to try to navigate to the folder c:\Users\Administrator\Desktop? or does it spit out the error without your interaction as well? maybe copying a few lines above the "[ERROR] Trace: Global unexpected error:" helps...
Is it possible that the list of files in the folder that you navigate to would be HUGE?
