True audio passthrough with "A/V Media" filter ?
Re: True audio passthrough with "A/V Media" filter ?
Aye Mr. Azik ;-)
@mrazik i dont have the original workflow from first page which was share through wetransfer but i can quickly rebuild the functionality for you.
Again, the original workflow here was using A/V Decoder to filter on the video but in the end, the original unmodified audio should be used.
Looking at the history of this thread, we can simplify the original workflow because it would "unpack video and audio", this is not needed; we can just work with the original source file's audio in the final wrapping step.
Workflow:
A/V decode->Video Filter->Encode->rewrap using original Audio
emcodem_use_original_audio_with_avdecoder.json
(4.65 KiB) Downloaded 884 times
Note that the final delivery path is set in the commandline proc. Also, i use mkv extension there hardcoded because the matroska format is virtually able to work with any audio track config and codec.
mrazik
Post by mrazik »
Hi @emcodem :),
thanks for the workflow, but does not help for my issue....
Point is that after A/V Media node I'm generating new H.264 file, but this file has than wrong audio dicrete tracks (all 16 went to single one with 16 channels).
Without using of A/V Media node in the transcoded file there is correct 16 discrete tracks.
I'm not sure what I'm doing wrong :(
Can you please advice?
Many thanks!!!
mrazik
DEVEL-AUDIO.json
(4.36 KiB) Downloaded 781 times
FFAStrans 1.2.2
Webinterface 1.2.0.4
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
@mrazik
It is because i was too stupid to upload the correct workflow
Pls try this
(4.65 KiB) Downloaded 882 times
mrazik
Post by mrazik »
emcodem,
you are a beast! It's working like a charm!
Ping me when you'll be in Prague, I'll buy beers!
Cheers,
mrazik
FFAStrans 1.2.2
8.00 GB RAM
NVIDIA Quadro K620
256GB SSD
1GB NIC
Windows 10 Pro 64b
Uhhh i really love Prague, been there once and i found the people so relaxed and generally cool :D
It's just a 3 hour drive from here so dont make promises that you cannot resolve ;-)
