@taurojo thank you so much for your reports!
Yes no worries, i understood that it worked for you when enabling UTF8 for windows... The problem is that this is a BETA feature of microsoft and it is not really documented what exactly it does so i cannot support this feature from my application.
I just tested a file with + and it was no problem. I was using 1.2 for it (ffastrans1.2 and webinterface 1.2)
Please, if you update to 1.2, ffastrans and webinterface (you can update webinterface before ffastrans), please make sure to DISABLE this UTF-8 for windows again and check if you still have problems.
I've upgraded to Webinterface 1.2.0.0 and it seems, that the performance issue was resolved.
But I'm sorry to inform you about another small bug: in Job Details page the bottom scroll-bars are missing in "Nodes" and "Log" quadrants. I have checked the behaviour in Chrome, Edge and Firefox and it's identicall in all of them.
JobDetails - scrollbars missing.PNG (202.97 KiB) Viewed 15411 times
BR,
Silicon
I have now spotted another issue: in Chrome and Edge the watchfolder files are still displayed in Incomming status although the transcode job was already finished. Firefox behave correctly. F5 fixes the issue.
File still displayed as Incomming although the transcode job is finished.PNG (52.6 KiB) Viewed 15410 times
BR,
Silicon
Hi @ArsenioV, this is most likely releated to something that's stored in the browser... i really need to come up with a reset button for it.
Can you try if it works in the private browsing mode?
