How do I input OP Atom files to create OP1A
Re: How do I input OP Atom files to create OP1A
Hello Julica97,
If you want to do an overlay, select Videolayer in filter category and put it after the Plugin processor atom to op1a and before your encoder.
Julica67 wrote: Fri Jun 19, 2020 7:54 pm It takes about 8-9 seconds for a small number of files, I am wondering if the time increases with the files number in the folder.
Let me know when it gets too slow for you, there is definitely room for improvement but i would like to collect more issues so when i change the code again, i change all things at once. First lets see if it does the basic job correctly...
