Converting and Processing Audio
Re: Converting and Processing Audio
Post by taner »
emcodem wrote: Tue May 16, 2023 7:03 am Is there a way to e.g. filter the voices nicely and clean from a whole movie?
You can try htdemucs (v4).
Pretty good results.
I'm not sure but I think they are also providing a gui both for mac and windows if necessary.
https://github.com/facebookresearch/demucs.
Apart from that Blackmagic has implemented Voice Isolation in DaVinci Resolve 18.
Very good results.
And with that I mean: very very good.
If you are looking for a standalone solution which does not need to be integrated into other apps or such else than this should satisfy your needs.
Best
Taner
big thanks @taner
already integrated demucs now :D Is there any way to utilize Resolve's capabilities in fully automated workflows? ..i always thought of it as a tool dedicated for manual usage only...
Post by taner »
this is all i know about.
Maybe i could be a starting point.
https://deric.github.io/DaVinciResolve-API-Docs/
Best
Taner
Hey @taner well thats good info, thanks a bunch!
Unfortunately it looks like BMD wants to expose the "script from outside" feature only for buyers of the Pro (studio) Version. Otherwise i would have probably developed some ffastrans modules to remote control a little this and that :D
But honestly, the whole thing is not designed to be a "run in background" solution - just being able to script the ui actions doesnt mean that it's a good idea to attempt to run it headless as windows service or such and build automations around it. But for a little here and then use, it would of course be a very nice solultion.
PA79
Post by PA79 »
Hi guys
unfortunately I had to put the project on hold for a short time. But now I am back in full swing. For the solution with the web interface, I unfortunately still lack the knowledge for the implementation. Therefore I would like to work as usual with a network folder structure. But in the future I would like to change the whole structure to the web interface
The most complicated thing was to generate the ffmpeg command to mix 5 audio files depending on the length of the (two) moderations and to provide a pleasant transition so that the audio files are not "hard" cut to each other.
ffmpeg command (works) :-)
ffmpeg -i intro.wav -i mod1.wav -i bumper.wav -i mod2.wav -i outro.wav -filter_complex "[1:a]adelay=9800|9800[mod1_with_delay]; [0:a][mod1_with_delay]amix=inputs=2:duration=shortest[intro_mod1_mix]; [3:a]adelay=2800|2800[mod2_with_delay]; [2:a][mod2_with_delay]amix=inputs=2:duration=shortest[bumper_mod2_mix]; [intro_mod1_mix][bumper_mod2_mix]acrossfade=d=0.3:o=1:c1=ipar:c2=ipar[crossfaded]; [3:a]atrim=0:-1[mod2_trimmed]; [crossfaded][mod2_trimmed]concat=n=2:v=0:a=1[pre_outro_combo]; [pre_outro_combo][4:a]acrossfade=d=0.3:o=1:c1=ipar:c2=ipar[final_output]" -map "[final_output]" -f wav -acodec pcm_s16le -ar 44100 result.wav
My command for the Command Excecuter Node in ffastrans would look like this (I hope I have not made a mistake)
"%s_ffmpeg%" -i "\\10.10.10.213\Daten\Dokumente\AUDIO TRANSCODER\MODULE TEST\ELEMENTE\intro.wav" -i "%s_job_work%\%s_original_name%_MOD1.wav" -i "\\10.10.10.213\Daten\Dokumente\AUDIO TRANSCODER\MODULE TEST\ELEMENTE\bumper.wav" -i "%s_job_work%\%s_original_name%_MOD2.wav" -i "\\10.10.10.213\Daten\Dokumente\AUDIO TRANSCODER\MODULE TEST\ELEMENTE\outro.wav" -filter_complex "[1:a]adelay=9800|9800[mod1_with_delay]; [0:a][mod1_with_delay]amix=inputs=2:duration=shortest[intro_mod1_mix]; [3:a]adelay=2800|2800[mod2_with_delay]; [2:a][mod2_with_delay]amix=inputs=2:duration=shortest[bumper_mod2_mix]; [intro_mod1_mix][bumper_mod2_mix]acrossfade=d=0.3:o=1:c1=ipar:c2=ipar[crossfaded]; [3:a]atrim=0:-1[mod2_trimmed]; [crossfaded][mod2_trimmed]concat=n=2:v=0:a=1[pre_outro_combo]; [pre_outro_combo][4:a]acrossfade=d=0.3:o=1:c1=ipar:c2=ipar[final_output]" -map "[final_output]" -f wav -acodec pcm_s16le -ar 44100 "%s_job_work%\%s_original_name%_MODUL.wav"
Now to my workflow idea: (biggest Problem)
Two watchfolders (Mod1 and Mod2) each followed by the node "audio extraction" with name extension "%s_original_name%_MOD1.wav" and "%s_original_name%_MOD2.wav".
In my idea there should be a "Hold" node, which waits for the respective file until it is in the cache and then forwards the files to the above ffmpeg command.
Like this?
I have already tried many variants of how ffastrans correctly fetches the audio stored in the watchfolder for further processing. But unfortunately all the ways I tried were a dead end.
If the ffmpeg command in ffastrans should not be correct it doesn't matter. with ffmpeg I have become quite good by now (and thanks to ChatGPT). The native ffmpeg command works fine.
I hope someone has a super mega great idea.
Wish you guys a nice Day!
PA
VST Host Test_emcodem_new.json
(67.25 KiB) Downloaded 669 times
Workflow idea.PNG (17.9 KiB) Viewed 14575 times
Aye PA,
without looking into the filter details of your ffmpeg cmd, the ffastrans version looks fine on quick peek. It might just be a good idea to use a STATIC variable instead of hardcoding UNC paths directly in processors but thats kind of an advanced topic.
Regarding your workflow, you cannot have 2 Watchfolders in one job, they would end up as 2 standalone jobs, one not knowing anything about the other. Here is why (look at workflows_equal.png picture): https://ffastrans.com/frm/forum/viewtop ... =849#p3565
You must start your workflow using 1 watchfolder and it is best to trigger jobs only when the LAST file arrived. So your user needs to throw to files into the folder, one called *_MOD1.mp4 *_MOD2.mp4 - in this case you would set to watch only for *_MOD2.mp4 (if that one is expected to be coming in after *_MOD1.mp4.
As it is not simple to merge branches after a split, it is best if you do all processing in serial, it goes like this:
watchfolder -> Audio extract2 -> Populate1 -> audio extract1 -> merge
The Populate1 node is the key, you need to save the current s_source and set s_source to the the other source file. E.g.
%s_mod_2% = %s_source%
%s_source% = "%s_job_work%\%s_original_name%_MOD1.wav"
You need to understand what value s_source has at any point in the workflow. After each Audio Extract processor, s_source points to the internally generated .wav file in the "work_dir". So after the second Audio Extraction, s_source points to the second generated wav file in the job_work_dir.
Last, in the ffmpeg command you posted, you would basically replace
"%s_job_work%\%s_original_name%_MOD1.wav" by "%s_source%"
and
"%s_job_work%\%s_original_name%_MOD2.wav" by "%s_mod_2%"
More infos about s_source:
https://ffastrans.com/frm/forum/viewtopic.php?f=5&t=849
https://www.ffastrans.com/wiki/doku.php ... _variables
PA79
Post by PA79 »
I tried for a really long time to get it solved with the variables. But I couldn't get it to work. Now I have solved it with a Python script that copies the audio extraction files back and forth wildly in the .ffastrans_work_root. but in the end it works. 8-)
That's how i usually solve my troubles ;)
