Merge Audio and Video Files
APerson
Re: Merge Audio and Video Files
Post by APerson »
I'm doing something similar to this, can anyone help me on my one
Link: viewtopic.php?f=5&t=940
edit* cant seem to post another one.
Hey Abul :lol: :lol: You got same project as me hahaha. No Plagiarizing :roll:
Can anyone help me with my one. Im getting so many errors i cant fix it :geek: :ugeek:
Coursework_video_process.xml
(21.59 KiB) Downloaded 687 times
I'll follow up here instead of your other thread, please do not cross post different questions over multiple threads.
Looks like you changed my example workflow from this very thread in a way that it cannot work anymore. Why would you insert 2 different watchfolders, one for m2v and one for wav - this will just end up in multiple jobs, all of them not knowing what to do?
Basically you need to understand the merging behaviour as explained in this thread:
viewtopic.php?f=5&t=849&p=3549&hilit=beginners#p3565
APerson
Post by APerson »
emcodem wrote: Wed Sep 18, 2019 1:54 pm Basically you need to understand the merging behaviour as explained in this thread:
Thanks,
abul
Post by abul »
APerson wrote: Wed Sep 18, 2019 12:57 pm Hey Abul :lol: :lol: You got same project as me hahaha. No Plagiarizing :roll:
:? oooooo K :|
Guys do you know why sometimes my nodes vanish and end up under other nodes. I was confused and thought i lost some work and didn't export to save it.
Hi abul,
The Workflow editor has several flaws. This issue and hopefully most (or all?) other editor issues has been properly addressed in the next version of FFAStrans.
abul
Post by abul »
Ah okay i see,
Does this command in the command executor make any sense?
%comspec% c/ %s_ffmpeg% -i "D:\Abul\Documents\Projects\Trans-Wrapping\merge\%s_audio_filename1%.wav" -i "D:\Abul\Documents\Projects\Trans-Wrapping\merge\%s_audio_filename2%.wav" -c copy -map 0:0 -map 1:0 %original_name%.mxf
Edit: I will have a transcoded video going in as well, but just wanted to if thats how you would execute a command
Pay attention to quotes and paths:
%comspec% c/ ""%s_ffmpeg%" -i "D:\Abul\Documents\Projects\Trans-Wrapping\merge\%s_audio_filename1%.wav" -i "D:\Abul\Documents\Projects\Trans-Wrapping\merge\%s_audio_filename2%.wav" -c copy -map 0:0 -map 1:0 "<what path???>\%original_name%.mxf""
abul
Post by abul »
Ok Thanks
abul
Post by abul »
Guys do you know how i can use the populate variable or the conditional to check if the name of a files contains certain characters
e.g
be able to say if Video_test_P2High, contains the value _P2High
I know i can select everything before the P"High from the previous help you have given, but is there a way for me to look for the string _P2High.
refer back to previous naming convention, name_somename_moreName_P2High
or name_somename_morename_High - don't need t do it for this one as i'm using the regext code provided before $regext("%s_original_name%","(.+)_High") to get the name cut and name the final file this.
but if my watch folder contains files with the P2High on it, the final name that i get in the delivey folder is .ext
Hi abul,
You can simply use wildcards like this:
Contains: If %s_original_name% = *_P2High*
Ends with: If %s_original_name% = *_P2High
Starts with: If %s_original_name% = _P2High*
Hope this helps.
