1.0.0. beta | Command executor
Locked
Post by taner »
Hello Steinar,
Are you considering implementing in command executor the choice between command console, power shell etc. in the upcoming 1.0-release?
At least in the latest beta-release it wasn't available anymore.
Actually a great feature.
Best
Taner
Re: 1.0.0. beta | Command executor
Hey @taner,
steinar is on holidays now, sorry :-)
Well spotted :-) that feature was reverted because the number of stuff to do was greater than the time to release. Meanwhile there is something much greater for you available in 1.0: the ability to build your own processor plugin with its own GUI.
Gui part needs to be done in HTML (can be very basic) but processor part can be any scripting or programming language you want. It Receives and and Gives Back a JSON file to ffastrans for reading and setting variables.
Stay tuned!
Post by taner »
Hi Emcodem,
thanks for the update !
Taner
Locked
