I think I found one.
Scenario:
I have unsaved changes in my workflow, I click to change to a different workflow, A message appears that asks if I want to discard changes, I then realize I didn't save my workflow so I say No. Obviously I right-click and save, but here is the bug, now it has saved the workflow on my screen with the unsaved changes over the workflow that I clicked that is still highlighted on the left. In this scenario I just overwrote and lost that workflow that I tried to switch to earlier. Successfully reproduced as well.
Sort of not a bug in a way as I think its saving over the wrong workflow just because you still have it highlighted on the workflow list after you say No.
Are you sure? Save workflow Bug
FFAStrans 1.2.0
2x HP SL230s
2x HP SL230s
Re: Are you sure? Save workflow Bug
Hi Noqras,
Yes this is obviously a bug and I will look into it. Thanks for notifying!
EDIT: Bug located and fixed.
