Having trouble executing python script
sunkast
Post by sunkast »
I am trying to use the command executor node to execute a YouTube upload script that I found from this github (https://github.com/tokland/youtube-upload). However when I run a known working command, the log says that the process exited with error code 1 and that 'python' is not recognized as an internal or external command.
I have tested this command in a Windows command prompt to confirm my command is working and it indeed does upload to YouTube. I also made sure that the path for Python is in the system environmental variables. So I have absolutely no idea why this is not working. Any help?
Attached is my testing workflow.
Youtube.json
(4.14 KiB) Downloaded 588 times
Re: Having trouble executing python script
Hi suncast, thank you for using FFAStrans and welcome to the forum! :-)
Maybe you should try adding the full path of the python.exe file, like "C:\Python27\python.exe", before your script?:
%comspec% /C ""C:\Python27\python.exe" "E:\FFASTtrans\youtube-upload\bin\youtube-upload" --title="%s_wf_name% %s_month% %i_mday%, %i_year%" --client-secrets="E:\Documents\gfqyoutube\client-secrets.json" --credentials-file="E:\Documents\gfqyoutube\matmen-youtube-upload-credentials.json" --privacy="private" "%s_source%""
If this does not help please send the log from one of your failed job. Right click on the failed job, select "Open log folder...", zip the content and send it.
sunkast
Post by sunkast »
That worked! Thank you so much for your help!
