FFAStrans CyberArk connector
Hi there,
for those of you using Cyber Ark in your company as a service, we announce that from today a new connector for FFAStrans is ready.
There are two connectors: Workflow Manager and Status Monitor.
The first one allows an headless VM to be created directly from Cyber Ark which runs and loads the Workflow Manager of your farm on premise and shows it and only it to the user. The other one performs a similar task, but loads the Status Monitor only like so:
Screenshot from 2021-10-19 14-46-53.png (32.58 KiB) Viewed 28554 times
This way is gonna be as if your employees working remotely had access to the status monitor and were able to run it on their laptop.
What they see is an instance that looks and feels as if they opened it locally, but it's actually a view from a newly created VM which is triggered to run and display that thing only.
Once the user closes the status monitor, the virtual machine is powered off and destroyed.
It will be recreated when another user is gonna trigger it.
To make use of this feature, request it to your local Cyber Ark support as it's been realized for Sky but it's available for every Cyber Ark customer.
Cheers,
Frank
