Creation Time | Variable | 1h Shift
Post by taner »
Hi Admin Team,
Hope you are well.
I have a problem.
When using one of the provided variables to get the creation time of a file I don't get the correct value.
For example: the creation time of the file is 15:43 (hh:mm) but I get 14:43 (hh:mm).
Exactly a shift of 1h.
I've tried it with several different files but outcome was always the same.
No special workflow was used (just output to a textfile) nor populating but only using the built-in variables as they are.
I'm using FFAStrans version 1.2.2
When using Windows Command Line to determine creation time I get the correct value.
Best
Taner
