I get a syntax error in a relative simple workflow using FFAS 1.4.0.1, the same flow works fine in 1.3.1.
See log and workflow attached.
Syntax error
bartcuijpers
Syntax error
- Thumb.json
- workflow
- (6.57 KiB) Downloaded 961 times
- 20240211-1427-2964-818d-7e4254d09fde.json
- logfile
- (94.69 KiB) Downloaded 917 times
Re: Syntax error
Hi bart,
@FranceBB is always interested in avisynth related issues.
Maybe meanwhile you can collect and upload the affected .avs file from the job_work directory, it has a name like *enc_stills.avs, e.g.
1-0-0~240211142733297~16304~20240211-1329-5294-5191-1d08a8c60794~enc_stills.avs
Re: Syntax error
OK, I can see that you're trying to index an 8bit RGBA FULL HD PNG.
"@type": "Image",
"Count": "130",
"StreamCount": "1",
"StreamKind": "Image",
"StreamKind_String": "Image",
"StreamKindID": "0",
"Format": "PNG",
"Format_String": "PNG",
"Format_Info": "Portable Network Graphic",
"Format_Commercial": "PNG",
"Format_Compression": "Deflate",
"InternetMediaType": "image/png",
"Width": "1920",
"Width_String": "1 920 pixels",
"Height": "1080",
"Height_String": "1 080 pixels",
"PixelAspectRatio": "1.000",
"DisplayAspectRatio": "1.778",
"DisplayAspectRatio_String": "16:9",
"ColorSpace": "RGBA",
"BitDepth": "8",
"BitDepth_String": "8 bits",
"Compression_Mode": "Lossless",
"Compression_Mode_String": "Lossless",
"StreamSize": "2481165",
"StreamSize_String": "2.37 MiB (100%)",
"StreamSize_String1": "2 MiB",
"StreamSize_String2": "2.4 MiB",
"StreamSize_String3": "2.37 MiB",
"StreamSize_String4": "2.366 MiB",
"StreamSize_String5": "2.37 MiB (100%)",
"StreamSize_Proportion": "1.00000"
and in your workflow you're trying to resize to FULL HD and re-encode to PNG
You're getting Validate: Script error: syntax error from Avisynth in the resize node.
I tested it against a similarly specced clip and I got the same result (i.e I was able to reproduce):
By analyzing the validation.txt we can see that the issue occurred at line 10, column 40 of the AVS Script, so:
and indeed we screwed up, 'cause we're not really setting any value for Primaries and Transfers in the new frame properties.
Arrrrrrrg frame properties, my hate for them just increased...
It should have been:
or whatever the values for your clip are.
This is a bug in the Stills decoder.
I found the lines incriminated and it's the fact that prime and transf in src.video.cspace fail to be retrieved and therefore are never populated.
I'll fix it and I'll give you a new processors.a3x.
If it works, I'll open a pull request so that Grandmaster Steinar can review it and eventually it will be part of the next release.
Oh I almost forgot: thank you a lot for spotting this! Once again this shows that it doesn't matter how hard we test, it's always the users that make the difference and help us in discovering new bugs, so thank you for finding and reporting this!
"@type": "Image",
"Count": "130",
"StreamCount": "1",
"Format": "PNG",
"Width": "1920",
"Height": "1080",
"BitDepth": "8",
LoadPlugin("\\mibctvan000\Ingest\MEDIA\temp\FFAStrans 1.4.0.1 Stable\processors\ffmpeg\x64\plugins+\ImageSeq.dll")
LoadCplugin("\\mibctvan000\Ingest\MEDIA\temp\FFAStrans 1.4.0.1 Stable\processors\AVS_plugins\JPSDR\x64\plugins_JPSDR.dll")
video = ImageSource("d:\.ffastrans_work_root\20240211-1137-4525-4975-86fa842ff669\20240213-1330-3044-79ad-5faddd6993f4\1-2-2~240213133133894~21304~20240211-1331-2841-3c6f-ebf1d5d13ffe~dec_stills.png", start = 0, end = 249, fps = 25)
audio = BlankClip(video, audio_rate=48000, sixteen_bit=true)
audio = GetChannel(audio, 1,1)
m_clip = AudioDub(video, audio)
m_clip = AssumeFieldBased(m_clip)
m_clip = propSet(m_clip, "_FieldBased", 0)
m_clip = propSet(m_clip, "_Matrix", 0)
m_clip = propSet(m_clip, "_Primaries", )
m_clip = propSet(m_clip, "_Transfer", )
Return m_clipand indeed we screwed up, 'cause we're not really setting any value for Primaries and Transfers in the new frame properties.
m_clip = propSet(m_clip, "_Primaries", 1)
m_clip = propSet(m_clip, "_Transfer", 1)
Return m_clipThis is a bug in the Stills decoder.
Re: Syntax error
Temporary fix in attachment.
Please swap it in the "FFAStrans 1.4.0.1 Stable\Processors" folder.
