Filenames produced by the "Stills" Encoder
amdx
Post by amdx »
first of all, thank you again for Ffastrans, I find myself opening it just to see what else I can do with it.
Since I often work with frame sequences (both as input or output), I have 2 questions about the "Stills" node.
The first one is about file names. I have noticed that the naming convention of individual frames output by the "Stills" node followed by the "folder" node seems to be: "filename_framenumber.ext".
I needed the name to be "filename.framenumber.ext", so I ran a python script after the "folder" node to replace the "_" splitter with ".".
Was there an easier way to do so in the folder node?
The second question is about frame numbers. If I place the "Stills" node after a trim operation, the first frame number of the image sequence is still going to be 0, even if the trimmed sequence starts at another frame. Again, I ran a python script to rename the sequence after the "folder" node, but I wondered if there was an easier way.
Considering that the "stills" node does have some features concerning frames (E.G. "force digits"), I was hoping to find a "first frame number" of "frame offset" feature there.
Thank you very much for any advice on how to improve my approach!
Re: Filenames produced by the "Stills" Encoder
Hi amdx,
You have some excellent improvement points there for the stills encoder! Just use your workaround if you're happy with it, until these features are natively supported. I cannot promise it for 1.4.1 but they will definately be on the feature wish list.
amdx
Post by amdx »
Hi Steinar!
Thank you for your answer. And thanks again for the software!!!
