Cloud Upload
willydoo
Cloud Upload
Post by willydoo »
First of all thank you for your work on that superb piece of software.
Being said, deliveies files to dropbox or google drive or owncloud will be a great value.
Still learning the software :)
Have a great day, peace
Re: Cloud Upload
Hi willydoo and thank you fo using FFAStrans :-)
If you have a local syncronizer for dropbox, google drive, onedriv etc. you can just deliver to that local folder and it will upload. Other than that I have not looked at the possibility for uploading directly to different cloudsolutions (of which there are plenty). But I might in the future :-)
