Speed Conversion
fabrice
Speed Conversion
Post by fabrice »
Hi
Is there a way to apply a speed change without altering the total amount of frames ?
I mean by that if you have a 240 frames video in 24fps you will have a 10 seconds video file but if you apply a speed change to 25fps you will still have 240 frames but the video duration will be shorter… ?
Best regards
Re: Speed Conversion
Please have a look at this thread:
viewtopic.php?f=5&t=237
Use the AviSynth example as a base for creating what you want.
