Populate variable with "."
Locked
kibi
Post by kibi »
When you try to set the value of string user variable to ".mp4" or any other starting with dot, processors.exe crashes.
Alexander Sorkin
Re: Populate variable with "."
Really? :oops: Thanks for reporting!
kibi
Post by kibi »
Strange, but yes. Hope it would be reproducible at your system. Or else I can send you the workflow ini file.
Alexander Sorkin
Yes, I can confirm the bug and it will be fixed, but not for the upcoming release. The next one after that ;-)
Locked
