Watermark
vijm1972
Watermark
Post by vijm1972 »
Please let me know how to locate .png watermark source location. My .png file is in shared storage location, I am trying below command but it's getting failed.
-c:v libx264 -preset veryslow -crf 18 -s 640x360 -aspect 16:9 -b:v 650000 -minrate 650000 -maxrate 650000 -bufsize 650000 -pix_fmt yuv420p -coder 1 -flags +loop -cmp chroma -partitions +parti8x8+parti4x4+partp8x8+partb8x8 -me_method 4 -subq 6 -me_range 16 -g 15 -keyint_min 1 -bf 0 -intra -refs 4 -sc_threshold 40 -i_qfactor 0.71 -b_strategy 1 -qcomp 0.6 -qmin 10 -qmax 51 -qdiff 4 -direct-pred 1 -fast-pskip 1 -vprofile main -vlevel 4.1 -movflags +faststart -c:a aac -ar 48000 -b:a 128000 -ac 2 -filter_complex "[0:1] [0:2] amerge" -vf "movie='\\tnc1.pfin.com\Techtest\FFMPEG\Logo\HDFINAL.png',scale=1920:1080[over];[in][over]overlay=0:0,drawtext=fontfile=/Windows/Fonts/arial.ttf:fontsize=80:x=700:y=900:box=1:boxcolor=black@0.5:rate='24000/1001':fontcolor=white:timecode='00\:00\:00\:00"
Can you please suggest how can I mention shared storage location of watermark. Watermark source location is \\tnc1.pfin.com\Techtest\FFMPEG\Logo\HDFINAL.png
If I used same command using local watermark path I am getting output without any error.
Thanks,
Vijay
Re: Watermark
When using paths in ffmpeg filters, you need to escape all "\" and ":" characters with a "\". So you get the following command:
-c:v libx264 -preset veryslow -crf 18 -s 640x360 -aspect 16:9 -b:v 650000 -minrate 650000 -maxrate 650000 -bufsize 650000 -pix_fmt yuv420p -coder 1 -flags +loop -cmp chroma -partitions +parti8x8+parti4x4+partp8x8+partb8x8 -me_method 4 -subq 6 -me_range 16 -g 15 -keyint_min 1 -bf 0 -intra -refs 4 -sc_threshold 40 -i_qfactor 0.71 -b_strategy 1 -qcomp 0.6 -qmin 10 -qmax 51 -qdiff 4 -direct-pred 1 -fast-pskip 1 -vprofile main -vlevel 4.1 -movflags +faststart -c:a aac -ar 48000 -b:a 128000 -ac 2 -filter_complex "[0:1] [0:2] amerge" -vf "movie='\\\\tnc1.pfin.com\\Techtest\\FFMPEG\\Logo\\HDFINAL.png',scale=1920:1080[over];[in][over]overlay=0:0,drawtext=fontfile='C\:\\Windows\\Fonts\\arial.ttf':fontsize=80:x=700:y=900:box=1:boxcolor=black@0.5:rate='24000/1001':fontcolor=white:timecode='00\:00\:00\:00"
Try it out.
vijm1972
Re: Watermark
Post by vijm1972 »
Thanks Steinar it's working perfectly.
