RESIZE node produces incomplete AVS
kibi
Post by kibi »
In the last version 0.7.6.1 RESIZE node generates AviSynth script without the last string
return m_clip
That's why any workflow with RESIZE stops with an error:
Resize@xxx: AviSynth script did not return a clip
Alexander Sorkin
Re: RESIZE node produces incomplete AVS
Oh but that's weird! Just did a simple with various resize settings and I cannot recreate the issue. Can you please send me you workflow so I can investigate?
kibi
Post by kibi »
Sorry for the delay.
720x576 letterbox SD 2 HD.zip
(3.3 KiB) Downloaded 624 times
Alexander Sorkin
When I import your workflow the custom avisynth node holding the "Sharpen"-template is empty, thereby causing the exact same error you posted. Can you please check if the "Sharpen" step is valid in your copy of the workflow?
kibi
Post by kibi »
At my side "Sharpen" node has the following content:
# Variables:
# m_clip		= The last returned AviSynth media
# _ffas_video 	= <original video>
# _ffas_audio	= <original audio>
# _ffas_height	= <source height>
# _ffas_width	= <source width>
# _ffas_work_fdr	= Working folder for the workflow
m_clip = m_clip.Sharpen(.30)
Return m_clip
I used "File/Export Workflow" function, may be it has missed some ini files.
Alexander Sorkin
Hm, if I copy your script into the Sharpen node everything works perfectly. No errors. There must be something wrong with that particular node.
Can you please locate the following file: FFAStrans\Processors\templates\.avs_custom\5368617270656E.ini
It SHOULD be your "Sharpen"-template. If it's not there but you still see it in your node then there is a bug. Because the error you're seeing is exactly the same as I see when the Sharpen-node is empty.
If you DO locate the file can you please send it to me? Also, can you try and create a new template with a different name but with the same script?
kibi
Post by kibi »
The content of the file is:
[template]
name=Sharpen
text_data=0x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
5368617270656E.zip
(679 Bytes) Downloaded 723 times
Alexander Sorkin
kibi
Post by kibi »
I have replaced Custom Avisynth Node with the new one and have made new template with the same code. And it has started to work normally.
Maybe it was the bug of migration from 0.7.5 to 0.7.6 (or to 0.7.6.1). The workflow had stopped working after the software upgrade. I definitely didn't touch the workflow.
Alexander Sorkin
It's hard to say what the cause was. The method for dealing with templates has changed much from 0.7.5 to 0.7.6 so it's not far fetched to say that it's a bug but at this time I cannot figure out what it is. Also, your template file seem to be ok. I've tried to export and import another workflow with the template and it works like it's supposed to. Do you have similar issues with other workflows?
kibi
Post by kibi »
No, I have not. It was the only workflow with Custom AviSynth. If you can not reproduce it in 0.7.6, then it's for sure the migration issue.
Alexander Sorkin
