CMD Node doesn't support negative exit codes
kibi
Post by kibi »
Hi!
18-10-2016 19-48-23.png (6.97 KiB) Viewed 7383 times
I have a batch file with exit code "-3", but FFASTRANS shows it as "4294967293".
Alexander Sorkin
Re: CMD Node doesn't support negative exit codes
Why being so negative, Alexander? ;-)
FFAStrans ask the windows api what the exit code for the executed command was, so it's basically the api getting it "wrong". But I think the exit code in windows are represented as unsigned 32bit so that might be the reason of this behavour. Sticking to positive exit codes is probably the proper solution.
