Mpeg I-frame
taurojo
Mpeg I-frame
Post by taurojo »
I need compress to:
File format: IMX 30 Mbps (MX1 wrapper OP1A).
- Video codec: MPEG-2 I- Frame Sony D10 30 Mbps.
- Binaría rate: 30 Mbps.
- Profile / Level: ML @ 422P.
- Sampling ratio: 4: 2: 2.
- Aspect Ratio: 16: 9 FF (Full Frame).
- Horizontal / vertical resolution: 720x576.
- Frame rate: 25 fps.
- GOP structure / size: I-Frame.
- Rate control: CBR (Constant Bit Rate).
- Interlaced Frame!!!!
Is it possible to do it with ffmpeg?
Or another workflow its possible.
THANKS FOR YOUR SOFTWARE!!
Re: Mpeg I-frame
Hi taurojo, thank you for using FFAStrans and welcome to the forum! :-)
Have you tried the "IMX-D10"-encoder supplied with FFAStrans?
