When tried to save an individual workflow or all workflows the program crashes with a message that reds:
Autolt Error
Line 54472 (File "C:\FFASTrans\FFAStrans.exe"):
Error:Subscript used a non-accessible variable.
The version used is the latest posted on the site 0.8.0.1
Workflow Save crashes the FFASTrans Manager
Re: Workflow Save crashes the FFASTrans Manager
Hi dlebrero, thank you for using FFAStrans and welcome to the forum!
Ther error does not add up with the line number it's pointing to. Exactly how are you saving, do you mean exporting?
I have the same message when exporting one or multiple workflows.
As far as I can see the export-error occurs when the workflow has a custom-ffmpeg-processor.
It doesn't matter which settings the transcoding-template has, even with the default-template the error occurs.
Best
Taner
Best
Taner
Thank you for that clarification, Taner! I will have a look at it.
Bug located and fixed.
