FTP monitor not working (0.8.2.0)
Soffort
Post by Soffort »
After update, my FTP monitors stop working. Trying to create new workflow but get the same. When I use "Submit files" on FTP monitor node, it works only with local or samba files, not for FTP. In 0.8.1.0 all works fine.
Re: FTP monitor not working (0.8.2.0)
Fixed in the next patch.
Soffort
Post by Soffort »
I have problem again with FTP monitor. I will try to check more conditions of this issue tomorrow for more detailed report.
Do you have any new info on the FTP issue?
Soffort
Post by Soffort »
I can't retry this problem anymore. Maybe, it was some old cache issue. Thank you for concern about it :)
