FFAStrans services not running
ksamson
Post by ksamson »
Hi There,
Im using FFAStrans to do a simple job. Workflow is very simple, just in folder > H.264 > out folder.
I tried to run it in my workstation first and it works fine. When I try to run it on my server (so that its not running on my pc), FFAStrans doesnt transcode anything, even if I submit the files manually.
Looking deeper, I saw that not all the services are running, through Task Manager, such as Process Manager, and Workflow Executor.
When I have it running on my workstation all these are running as well:
FFAStrans workflow manager (32 bit)(4)
Console Window Host
FFAStrans processor manager (32 bit)
FFAStrans workflow executor (32 bit)
When I run it in my server (every setting mirrored) all i get is this:
FFAStrans Workflow Manager
Can you advice how to run the other services?
Re: FFAStrans services not running
Hi ksamson, thank you for using FFAStrans and welcome to the forum! :-)
Can you please go to "Options -> Configuration -> Host" and enable "Enable local workflow processing as application? Alternatively, you can install FFAStrans as a windows service from the same config menu.
