Conditional: audio file without video?
I'm trying to differentiate a workflow I have in place by setting a conditional that checks whether a file has video and audio or if it's audio only and use a different node.
I know that there's a conditional for videos without audio, but what about audio files without video?
Thank you in advance,
Frank.
Re: Conditional: audio file without video?
Hello Franck,
It seems quite easy with conditional node, you have to use %i_a_streams% and %i_v_streams% with larger than or egal to check you have more 1 audio stream and more 1 video stream > audio+video.
Then, if you have always video+audio file OR only audio file, you can execute on success when file is video+audio and execute on error if your file is only audio.
I hope it helps.
