original_manual:audio_mapping
FFAStrans supports sophisticated audio channel mapping from the source to the output.
Track/stream <no. >
The number of discrete tracks dependent on the"Discrete tracks" settings. So if you have selected 2 discrete tracks, you can map what ever source channels you like to those tracks. If you specify source channel(s) that does not exist, it will be replaced by a silent channel. The notation for channels mapping is either integer numbers or variables separated with a comma (,) but pipe (|) and semicolon (;) is also supported as separators. The number of channels specified in the strings will determine the number of channels per discrete track.
Example:
Specifying "1,2,3,4" in an input field will give 4 channels in one track, starting from the 1'st channel found to the 4'th.
As stated, variables are also supported, either as separate channel representation or a complete set of channels.
E.g. if %s_channels% = 3,4,5
Specifying "%s_channels%,2,1" in an input field translates to input channels "3,4,5,2,1". This would give 5 channels on one track.
original_manual/audio_mapping.txt · Last modified: 2025/02/16 15:27 by 127.0.0.1
