original_manual:def_watcher_conf_maintainance
Keep all job work folders on completion
Enabling this option will prevent FFAStrans from deleting all the files and work folders it creates for jobs.
Note: You should avoid enabling this as the it may fill up your storage. Use only for debugging.
Keep only failed job work folders
Enabling this option will prevent FFAStrans from deleting the work folders for failed jobs.
Note: In this regard, a job is considered failed only if the last executing branch has failed outcome.
Keep work files for <n> days
This option tells FFAStrans how many days it should keep the work folders for each job.
Cleanup time
THIS OPTION IS DEPRECATED. CLEANUP IS NOW ALWAYS SET TO MIDNIGHT.
Validate records after <n> days
THIS OPTION IS DEPRECATED. IT WAS BADLY IMPLEMENTED AND DID NOT WORK ACROSS ALL MONITORS. USE THE "FORGET MISSING FILES" IN THE MONITORS INSTEAD WHICH HAS BEEN IMPROVED AND NOW SUPPORT ALL MONITORS.
original_manual/def_watcher_conf_maintainance.txt · Last modified: 2025/02/16 15:27 by 127.0.0.1
