original_manual:enc_a_audio
Format
Bit depth
Bitrate (kb/s)
Sample rate
Discrete tracks
Source channels as tracks
Same as source
Total channels
Set custom mapping
Wrapper
Use RF654
Conform volume
original_manual/enc_a_audio.txt · Last modified: 2025/02/16 15:27 by 127.0.0.1
