original_manual_htm:avs_v_safecolorlimiter
With this filter you can get Broadcast Safe luma and chroma levels (0.0-0.7V) in Limited TV Range depending on the Bit Depth
Bit Depth
Sets the Bit Depth. Recommended: Auto.
8bit sources will be limited to 16 - 235 luma and 16 - 240 chroma
10bit sources will be limited to 64 - 940 luma and 64 - 960 chroma
12bit sources will be limited to 256 - 3760 luma and 256 - 3840 chroma
14bit sources will be limited to 1024 - 15040 luma and 1024 - 15360 chroma
16bit sources will be limited to 4096 - 60160 luma and 4096 - 61440 chroma
32bit sources will be limited to 16/255.0 - 235/255.0 luma and -112/255.0 - -112/255.0 - 112/255.0 chroma
original_manual_htm/avs_v_safecolorlimiter.txt · Last modified: 2021/02/07 10:48 by 127.0.0.1
