Change volume level to -12db
Re: Change volume level to -12db
movalex wrote: Wed Sep 29, 2021 9:05 am BTW I guess the values below -12, such as -12.3 are fine. They just should not go higher than that.
Hmmmm what can i say to that... it is my passion to change the original as little as possible when processing, so typically when applying a normalize, i do this only in order to fulfill some strict requirement that has been written down to paper and we are contracted to deliver exactly this and that values. E.g. EBU R128 allows +-1db for raw stuff like live and news or such but -+0.3db for films and series. Do you really not have a clear and exact goal to fulfill here?
In case this is only for scientifical interest, i would probably gather some more infos about the "why first pass normalisation is not exact" and probably even come up with a workflow that outputs always guaranteed -12db... Just let me know your goal.
movalex wrote: Wed Sep 29, 2021 9:05 am ...is it possible to grab somewhere that early build of FFA 1.3 for testing?
Yeah using variables makes you very mighty :D
Regarding the some 1.3 build for testing, i fear it is not yet ready for it or better we are not yet ready for it. What you would get is "under construction", so it would not make sense to report any bug that you find because the devs are most likely aware of it anyway... You could not make any difference between stuff that is currently under construction and real bugs. I fear it will take some more months until we are at a point where it makes sense to give it away for testing. Even then we dont yet have any procedure or plan for user testing of betas... it is something we need to work out definitely.
Anyway, if you desperately want to test the first workflow to be able to compare the results to the second one, let me know and i will come up with a patch for processors.a3x which allows you to do so.
emcodem wrote: Wed Sep 29, 2021 5:05 pm I fear it will take some more months until we are at a point where it makes sense to give it away for testing.
Spoiler alert: maybe just maybe a Christmas Eve present, but don't count on it too much as it was just a late night conversation with Grandmaster when I was half-sleeping already eheheheheheheh
We're still testing 1.3 Test 6, patched some bugs and worked on new things but we still have a long way before releasing everything to the public. Still, you should know that as always when it comes to a significant bump in the release number, new features arrive, so you're gonna see lots of new interesting stuff, which, of course, need testing... a lot of testing eheheheheh
