Damn, i just opened your sequence and i stil see MY results from above instead of yours.
To be honest, i still think that what you see depends on the "decoder", so no matter what you do it might still behave different for your users.
Anyway, sure i want to go on to find the bottom of your issue but i am running out of ideas.
We have guaranteed now:
-) the same sequence https://drive.google.com/file/d/1T6vAzH ... sp=sharing
-) the same files https://drive.google.com/file/d/13AqqFg ... sp=sharing
-) when i extract the sequence and the file folders into the same directory, it automatically finds the clips in the sequence, no need for relinking the files.
Still we are seeing different results in Adobe Premiere regarding the audios in the clips.
...i also want to summon everyone here: @admin @momocampo @FranceBB @ghatis @taner @ThomasM @authorleon @Vladimir @crispyjones
What else could we try to get the same result, any idea? I am on windows, are you, Mahmoud, on Apple maybe?
This screenshot is from loading the exact same project file with the exact same input files but it shows different results than on mahmouds try above:
Audio not sync after encode.
Hi ,
now, my turn
I tried to reproduce your screen : Same files at same places, same timeline scale(00500->01000). I think I have the same result as @encodem.
What are we missing here?
now, my turn
- try.png (56.7 KiB) Viewed 7885 times
Mahmoud Rady
Yes, I'm using windows machines. I have also tested the files on an Apple machine on Avid Protools and I see the same sync issue.emcodem wrote: Tue Jun 09, 2020 8:32 pm
@mahmoud,
we are a little dependent on you here as momocampo and me both open the same sequence but still see different results.
Whats your premiere Version?
Do you think when you install a totally fresh premiere and open our project that you see my results or your results? Maybe you can try this?
What about the md5 checksums i posted above, can you confirm they are the same for you?
