Partially transcode big file
movalex
Post by movalex »
Hi!
I'm doing some test rendering, is it possible to partially transcode input file with FFAStrans?
With ffmpeg I use -t ans -ss options for this.
Re: Partially transcode big file
Hi @molavex
You can try the Api_Set_In_outpoint.xml example workflow, just ignore what the thread is about, you don't need to use any api stuff for it.
viewtopic.php?f=5&t=849&p=3586&hilit=cut#p3586
The first processor lets you safely set in and outpoint.
The middle processor is a custom avisynth which takes the variables that you set inn the first processor and instructs avisynth to cut the file as you wish.
Hello Movalex,
You can also use a custom ffmpeg node and just type :
-ss 5 -to 10 -vcodec copy -acodec copy
Replace "5" and "10" by what you want.
Add %s_original_ext% in extension box to keep your original extension.
To resume :
Monitor folder>custom ffmpeg>delivery node.
Hope this helps.
movalex
Post by movalex »
Oh, thanks, guys!
