Upgrade database crashed on line 22724
movalex
Post by movalex »
Hi!
I'm trying to upgrade my current 0.9.4 version to 1.0.0 final, but I get an error Subscript used on non-accessible variable.
Line 22724 of _convert_db.a3x
I deleted all executable files and processors from 0.9.4 folder, downloaded again both installers and tried to copy and launch from scratch, as advised, but that did not help.
Annotation 2020-02-06 210436.png (7.43 KiB) Viewed 12778 times
And... there's a typo on Converting main config window title :)
Annotation 2020-02-06 210729 (2)_LI.jpg (31.77 KiB) Viewed 12778 times
Re: Upgrade database crashed on line 22724
Hi movalex,
There is no 1.0.0 final yet but thank you very much for reporting! We will take a look at it.
Sorry but I need some more help. Does it crash on the "Converting main config..."? or is it somewhere else?
BTW, could you please try this file and run the update again? Just rename from xml to a3x. Maybe you need to delete the "\FFAStrans\Processors\db" folder.
_convert_db.xml
(529.2 KiB) Downloaded 646 times
movalex
Post by movalex »
Hi, Steinar!
Sorry, I meant 1.0.0 beta 7.1, which is called final beta.
Probably I ought to create the topic in a dedicated forum branch.
However, I tried this version of converter, and the error line changed to 22892. Everything else left the same: conversion stops at 65%, and goes on until Cancel is clicked. Yes, it does not technically crash, but instead tries to convert in loop.
Here's my workflows, if it helps:
Workflows.7z
(6.54 KiB) Downloaded 630 times
Thanks for the reply and the workflows :-) I did expect it to crash again but now I have the proper means for locating the error. It should be an easy fix and I will post a new file when it's fixed.
movalex
Post by movalex »
Cool!
By the way, I love Error 2001 (on creating loop workflow) :)
Hehe, yes I hope I have more sense of humor than that crazy HAL ;-)
Please try out the new file attached.
_convert_db.xml
(529.24 KiB) Downloaded 667 times
movalex
Post by movalex »
Yess!
Thank you, now the db is properly converted and all is working. Thanks!
