Reset workflow the only way to work
aollaku
Post by aollaku »
Hi folks,
I`m new with FFAStrans software. I`m trying to make it works but no luck. I have created a workflow very simple. Only three steps:
1) Monitoring Folder (Watch Folder)
2) Audio Extraction (convert to MP3)
3) Distribution Folder (Output Folder)
The only way to run the workflow is to right-click on the workflow and select reset from the menu.Image Image
Thank you
Re: Reset workflow the only way to work
Hello Aollaku and welcome to the forum !
With what you said "The only way to run the workflow is to right-click on the workflow and select reset from the menu" it would seem the cache history is enable. That's means each time your file is processed, FFAStrans "remembers" the file. You can avoid this : check "forget missing file" in Monitor folder to help FFAStrans to "forget"the file.
Please let us know if it is ok :)
aollaku
Post by aollaku »
HI momocampo,
I don`t see any option like that on monitor folder. Where can i find that option??
Best,
Andi
aollaku
Post by aollaku »
sORRY MOMOCAMPO,
I found that option but is not enabled.
Best,
Andi
Hello Andi,
Yes and you MUST enable it if you want FFAStrans forgets your file once processed :)
So, check "forget missing file", reset your workflow once and it would be ok.
