We want to conditionally prepend a disclaimer to a video, and to accomplish that, we generate a png file before the FFAStrans job begins.
The Insert Media works as expected, but I'm unable to get a simple conditional to recognize if the disclaimer file exists or not.
To test this and get it working, I've set up this workflow.
- Populate variables, mimicking the API submission of the job
- Test if the Disclaimer file exists or not
- If NOT found, write a text file "NOTFOUND.txt"
- If found, write a text file "FOUND.txt
i copied/pasted the conditional from the help text, and am certain the file does NOT exist, yet the only process that it continues on to is the result of a successful test - it never takes the failed test path. Is there something blatantly wrong with any of these nodes that I'm somehow missing?
- 2-9-2020 8-44-17 AM.jpg (97.84 KiB) Viewed 9420 times
