Conditional Node with Binary Outputs
philthewiz
Post by philthewiz »
Hi!
Thank you again for your great work!
Simple request and a bit late for the next release. I would find useful to have a true/false outcome in the conditional node.
It would prevent to create 2 nodes instead of one for easy proofing. Such as, Interlaced/Progressive.
I know there are scenarios that are not binary but it would still be useful.
Thank you! :)
Re: Conditional Node with Binary Outputs
Hello Philthewiz,
Maybe I don't understand your request but you HAVE true/false in the conditional node.
You just have to enter a variable inside the conditional node and if the condition is ok the workflow will continue to next node with green square as input (execute on success) OR if the condition is NO ok, then connect another node with red square as input for next node (execute on error).
And voilà, no need to create 2 nodes :)
You can look here :viewtopic.php?f=5&t=849
Scroll down until " Example Workflow: Error handling".
cheers.
Ghtais
Post by Ghtais »
Hello all
Hooo, thank you for this post guys !! I'am discovering this amazing function witch is very useful.
I designed a lot of workflow without knowing that, increasing number of useless conditional nodes.
It will help a lot !!
Cheers
Hello Ghtais,
This is quite unbelievable that you don't know this function, by the way, I wonder how people do without knowing this function :)
Anyway, happy you learned something useful.
Cheers l'ami ;)
philthewiz
Thank you! It cleared some of my problems :)
philthewiz wrote: Thu Feb 13, 2020 2:35 pm Thank you! It cleared some of my problems :)
You're welcome ;)
Feel free to ask if you need help.
8-)
